(North America excluded) 7.7-20.5 kWh | High voltage battery
PDF İNDİR >>
Rapid charge
IP65
GoodWe’s Lynx Home S Series is a high voltage battery that offers multiple energy storage options through an expandable modular design (3-8 modules combined), which further simplifies installation and O&M with multiple smart functions. The safest battery cell technology (LFP) comes with a high charging rate, ensuring superior performance and supplying robust power for your life.
Ultra rapid charge
Auto under-voltage reboot
Remote diagnosis & upgrade
IP65 protection level
Rapid charge
IP65
When Lynx Home S Series batteries are compatible with inverters that allows 50A max. charging current, the whole system can be fully charged within only one hour.
The GoodWe Lynx Home S Series is especially designed with IP65 for more flexible and easier installation indoor or outdoor. With inbuilt remote diagnosis & upgrade and auto under-voltage reboot functions, Lynx Home S Series helps you economize on the time-consuming installations and maintenance with minimalized efforts.
Wall-/floor-mounted Installation
LX S7.5-H
Usable Energy (kWh)
6.91
Nominal Voltage (V)
153.6
Max. Continuous Charging/Discharging Current (A)
50
Installation Location
Wall-Mounted / Ground-Mounted
Enclosure Type
IP65
LX S10-H
Usable Energy (kWh)
9.22
Nominal Voltage (V)
204.8
50
Enclosure Type
IP65
LX S13-H
Usable Energy (kWh)
11.52
Nominal Voltage (V)
256
50
Enclosure Type
IP65
LX S15-H
Usable Energy (kWh)
13.83
Nominal Voltage (V)
307.2
50
Enclosure Type
IP65
LX S18-H
Usable Energy (kWh)
16.13
Nominal Voltage (V)
358.4
50
Enclosure Type
IP65
LX S20-H
Usable Energy (kWh)
18.43
Nominal Voltage (V)
409.6
50
Enclosure Type
IP65
BÜLTEN
MONTAJ KEYFİ
