Low voltage
Latin
98.8%
Max. efficiency up to 98.8%
Full-load running at 50°C
String level monitoring
130% DC input oversizing
110% AC output overloading
PLC Communication
Low voltage
Latin
98.8%
DC input current 15A
GW12KLV-MT
Maks. Giriş Voltajı (V):
800
3/2
Maks. Verimlilik:
98.7%
Nominal Çıkış Voltajı (V):
220, 3L/N/PE or 3L/PE
GW15KLV-MT
800
3/2
Maks. Verimlilik:
98.7%
GW20KLV-MT
800
3/2
Maks. Verimlilik:
98.8%
BÜLTEN
MONTAJ KEYFİ
